This is sold at the DIYdrones store. I bought one - and I can fine no pictures manuals YouTube videos - zip, 0, 0.
Remzibi OSD 3DR- references can't be found.
Remzibi has not posted on RCuniverse, or DIYdrones for ~ six months.
Does anyone know why I can't find info on this OSD. Its a purple board with two button switches.
Every reference refers to early versions (red).
Please - bernienepper
Tags:
Permalink Reply by Andrew Radford on January 26, 2012 at 12:02am Wiki is here. The reason why there is not much info is that it is only new. Rembizi OSD has been around sine 2008 I think? Anyway a lot longer.
Permalink Reply by bernienepper on January 26, 2012 at 8:32am Ardupilot Mega MinimOSD
https://store.diydrones.com/Ardupilot_Mega_Minimal_OSD_p/br-apmmino...
This is what your talking about
Remzibi OSD 3DR
https://store.diydrones.com/Remzibi_OSD_3DR_p/br-remzibiosd.htm
This is what I'm talking about
Permalink Reply by Andrew Radford on January 26, 2012 at 8:53am Ah right you are. Should have read more carefully
Permalink Reply by Burt Green on January 26, 2012 at 8:43am I think that Remzibi OSD 3DR is from this design.
http://www.rcgroups.com/forums/showthread.php?t=921467
posts 3884 and 3885 give the impression it's the same OSD board.
Permalink Reply by criro1999 on March 8, 2012 at 7:37pm Thanks for sharing this information about pins.
A question please: Which pin is used for "Virtual ADC which keeps a running total for use with battery MAH consumption"?
Permalink Reply by Keith S on March 8, 2012 at 7:46pm It is done through the ADC 6 input and calculated in the Remzibi code on the ATmega32.
I'm using the Attopilot 90A sensor http://www.sparkfun.com/products/9028 and works great. I am using a gain of 0.14286 on the advanced ADC config tab.
Permalink Reply by criro1999 on March 30, 2012 at 7:08pm Hi Keith, do you know a way to enable/disable Remzibi OSD output using a spare channel from TX?
Permalink Reply by Keith S on March 30, 2012 at 7:48pm
Permalink Reply by Keith S on March 30, 2012 at 11:06pm
Permalink Reply by criro1999 on April 1, 2012 at 1:38pm Indeed, this was the question. To hide or show Remzibi alphanumeric output signal (using a TX channel), but keep the video camera signal. Other OSD like EZOSD has that feature. I don't want to toggle power off/on the full rezmibi, but the alphanumeric only. I believe this would be a cool feature.
Permalink Reply by criro1999 on April 6, 2012 at 7:54pm Hi Keith, Which pin should be used for RPM input or "Frequency Counter" (using optical sensor)? May I use a eagletreesystems optical sensor with Remzibi OSD? I did not find any info about sensors in the published manual for Remzibi.Thanks, Chris
1289 members
248 members
57 members
87 members
Powered by
