I managed to break the antenna off my Turnigy 9x Rx in a crash. The grey lead was cut about halfway down, disconnecting the big red heat shrink wrapped thing.
In doing this, have I severely reduced the range of my radio?
The wire looks like it's a very small coaxial cable. How do I go about fixing this? It doesn't look trivial to solder.
Cheers,
Chris
Permalink Reply by arashi on April 22, 2012 at 12:01am Yes, it would greatly reduce your range as the exposed part of the antenna is under the red shrink wrap.
It is a very small coaxial cable that has the outer shield removed for a quarter wavelength I believe. You just cut off the red shrink wrap and accurately measure the length of the exposed center wire, then see if you have enough grey coax left that you can strip an equal amount of the shielding from the remaining part.
If you don't have enough wire remaining. Just open up the case and solder a quarter wavelength piece of regular wire in place of the coax.
Alternatively, you could just buy another one for $9US. If they are out of stock, I'd sell you one of my spares, but your in Australia, so it would probably take just as long...
Permalink Reply by Christopher Cooper on April 25, 2012 at 8:46pm Thanks for the info. I think I managed to cut the antenna in the most inconvenient place.
At $9 I'll just buy another one.
Thanks again!
Chris
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1280 members
16 members
182 members
86 members
51 members
Powered by
