I managed to do something stupid while removing compass board from imu after crash. I was gently heating the pin ends which hold compass board in imu board, but somehow applied too much force when removing it. The other side wasn't melted enough and bye bye VCC solder pad. Millimeter of pcb lead stripped off too... I was wondering if i could save the unit by soldering jumper wire from the next point of pcb lead. To the question then: What is the next point of VCC after initial soldering point (pin header). The lead goes under first ic chip (30 0701 722) and i cannot say whether it connects to ic itself or somewhere else. Is there anywhere PCB layout pics of compass board?
Compass PCB V2.0
Thanks in advance!
why don't you do a quick search?
the link is in the shop where you bought it: board layout
