Does it mean if I have 3s battery that I need to put in only three resistors?
If I solder in all four supplied resistors, will it not affect the voltage reading of the APM?
Thanks for any insights :)
Tags:
Permalink Reply by Dave on April 16, 2012 at 6:51am I'm assuming you have an APM1. You only need to put in one resistor as per this page:
http://code.google.com/p/arducopter/wiki/AC2_Current
It only monitors total battery voltage so only needs one resistor. The other wires from the balance lead go nowhere on the board.
Be VERY careful that you connect the battery positive wire to the correct pin (red wire). If you accidentally connect it to earth pin (where the black wire is shown), you'll produce a short-circuit across the APM board which will vapourise earth tracks and possibly destroy the board.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.671 members
1280 members
8 members
182 members
15 members
Powered by
