Rotation Speed and Rotation Velocity
I am trying to model my quadcopter using the Euler's Equations. To get the accelerations and angular speeds, I am using an accelerometer along with a Gyro.
My question is, for a specific flight data sample, are the angular velocities in Euler's Equation above simply the raw angular speeds I get from the gyro around the x, y, and z-axes respectively?
In this project, it can be seen under "Kinematics" section, that the author uses some sort of a matrix to transform from the angular speed to the angular velocity!
So what is the right way to do it?
  • So to answer my question, and to be more specific, I am using the gyro on an Android phone, which returns the angular velocities that the Euler's equation involve. So the answer is yes.
    The author of the above project is using a matrix to convert from Euler's rate vector to angular velocity vector.
    I hope this helps somebody one day
