RSSI Data Reading Problem with Pixhawk and MinimOSD
Hi Guys,
I can not read max/min range of RSSI data with Pixhawk and can`t monitor and map it to % level on MinimOSD. The readings are oscillatory around some value due to some noise I guess.
After some readings I set the following values on MP. But it didn't work.
RSSI_Pin to 103 and
RSSI_Range 5 V
I am using Sik radio with Futaba 10J RC. How can I read RSSI values correctly and map them on MinimOSD? Any suggestions?
Thanks and Regards.
