RSSI Logging?
My receiver outputs received signal strength and I have connected this to the A0 pin on the APM. I have set the RSSI_PIN paramenter appropriately and can display the RSSI correctly in the MP while the quad is attached to my PC. Is there any way I can log this parameter during a flight? While I do have the RSSI available on my transmitter via telemetry, it would be nice to now exactly how the RSSI varies with regard to the distance and orientation of my quad so I can optimise my antenna and also keep it in range while sending it on missions (just in case...)
  • Great question!  Have you found a solution yet James?
