Looking to sell this complete setup. This is probably the cleanest wiring and the best built quad I have ever seen. All wires are cut to length and have custom pigtails. The camera mount shown in the last pic is not included but can found at http://www.shop.aglhobbiesllc.com/ for a nice setup. The carbon plates sit on rubber dampening mounts. I have replaced the stock phillips screws with black hex bolts so they match. The spektrum AR6100E receiver is included but if you dont have spektrum I will take off $35. Asking $500 shipped. I am located on a military base and shipping will take a tleast 2 weeks to clear customs and get back into the US FYI. Basically hook up your receiver run through the setup with the GCS and your ready to fly. Will write the PIDs for easy setup.
Mikrokopter 400mm frame http://www.nghobbies.com/cart/index.php?main_page=product_info&...
4 Pulso motors ($45 each) http://montorc.com/x2212L22.aspx
5 Turnigy 18amp escs (1 extra)
APM v1.0 and Hotel Oil Pan
magnetometer and gps
xbee w/ wire antenna
LED strips on each arm
2 extra arms 1 red 1 black
6 extra props 3 each rotation
extra landing gear
3s 2500mah pack OR 2 1800 saddle packs(your choice)
silver prop spinners and original motor nuts included
Tags:
Email address is w4hfv@juno.com if interested.
Permalink Reply by Casey Levinger on July 30, 2011 at 12:38am is this still for sale? I would love to get my hands on this one!
Still for sale. Be happy to send some more pics or answer any questions about it.
Permalink Reply by Casey Levinger on August 2, 2011 at 10:55am
Permalink Reply by Denis Duckett on August 3, 2011 at 5:19pm Neil, were you successful in getting APM v1.0 to Position Hold, and Alt. Hold?
Denis, I have not tried Position hold. Altitude hold worked but it wasnt as accurate as I thought it would be. About 5 feet up and then 5 feet down after about 30 seconds.
Casey, This handles the gopro no problem. It can probably handle something bigger but a SLR camera might be pushing it. I put the higher output "L" motors on it which helps. I strapped 2 4500mah packs to the buttom a while back and it had no problems flying.
Has this been sold?
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
11 members
182 members
1290 members
684 members
Powered by
