I would like to know the setting to adjust the throttle setting that is used during RTL. When I activate RTL the throttle is advanced to 75% (I think as this is the maximum autopilot setting), the aircraft (Skywalker 1900) gains altitude very slowly (it seems) for this throttle setting. I have an airspeed sensor installed, as I understand it the Ardupilot uses throttle increase (airspeed) to achieve the RTL set altitude.
If I fly manual/stabilize modes I can use a lot lower throttle setting to climb to a higher altitude.
What Ardupilot Parameters whould I change to have the Ardupilot set a lower throttle setting (airspeed) to achieve the RTL selected altitude?
Will changing this parameter change how it works in other modes?
Does the Ardupilot use elevator (pitch up) to achieve the higher altitude?
Exactly what happens when RTL is engaged? What is the main parameters used?
All I would like to change is for my Skywalker 1900 to climb to the RTL set altitude quicker and with the lowest throttle setting required.
Thanks for the help.
Todd
Tags:
Permalink Reply by Todd Nelson on November 27, 2012 at 9:59pm Bump.
Really need some help!
Permalink Reply by mack goodman on December 4, 2012 at 10:33am All good questions... I expect the answers are very involved and probably written down somewhere if you could put it all together.
I don't have an understanding of all these things yet either, but I would like to learn.
Permalink Reply by Søren Kuula on December 4, 2012 at 2:38pm Hi,
Have you tried
Regards
Soren
51 members
133 members
1298 members
249 members
Powered by
