Selling 900Mhz Xbee Series 1 Telemetry Kit Assembled New Plug n Play (Reduced Price)!!!
For Sale: Xbee Telemetry Kit Assembled and programmed all ready to work with APM 1.0, 2.0 and mission planner
 This is an excellent kit for long range use. Buy using the RPSMA connector on the UAV you can remote mount the antenna via coax like RG-174 because RF does not like to go through carbon fiber very well
Or you can solder a short piece of wire 16ga wire to the center conductor
Wire Length:
1/3 wavelength 0.333 meters, (33,333 cm)
1/4 wavelength 0.08333 meters, (8,3333 cm)
Note: 1/4 wavelength will require a ground plane
so you do not half to use a connector on the UAV side
Includes insured priority mail shipping
Asking:175.00
PayPal
Includes: Series 1 not Series 2
2: XBee-PRO 900 extended range module w/ RPSMA connector
1: XtreamBee Board (No XBee included)
1: XtreamBee USB Adapter
1: Telemetry Cable
2: Antenna 900MHz RP-SMA 3.1dBi
Shrink tubing was added to protect the boards after assembly
Both modules have the latest firmware and are programmed, tested and are ready for use just pug and play.
Uploaded from the Photobucket iPhone AppUploaded from the Photobucket iPhone AppUploaded from the Photobucket iPhone App
Tags: 2.0, 900Mhz, APM, For, Kit, Mission, Planner, Sale, Telemetry, Wireless, More…Xbee
Still for sale!!
These are Series 1 Xbee's
What is the reason, you want to liquidate the pair you have ?
i am shifting my video helicopter build to use a industrialized auto pilot system instead of the APM 2.0 so i dont need the Xbee's. They are configured tested with mission planner they are new only bench tested.
Like new ready to go
