Hello All,
I am working on my first drone, using an E-Flite UltraStick. So far the build has been going well. I developed a system for switching between radio and arduino control. I am working on developing my PIDs. I got a decent bench test in today. So I tried mounting my sensors to the plane to make sure I would not have issues with electronic interference. As it turns out, I am having mechanical interference. When I hold the sensors above the plane, no problems. As soon as the sensor make contact with the plane with the motor running, my sensor values go all over the place. What should I do!!!
I am leaving for a trip to Idaho next weekend, where I was planning the maiden flight of my system. If need be I can order new sensors to be delivered to our property...
I am using some osepp brand sensor I bought from frys. They run an ADXL345 (accelerometer) and MPU 3050(gyroscope).
I wrote a program to try and filter the values. I filled an array of the 20 previous values and took the median. This worked on an earlier project but is no longer sufficient. In addition, it creates a sizable delay in my sensor values...
What should I do?
