Servo Scripting Troubleshooting
Hey guys!
I am having a couple of issues of testing servos out through scripts. I have successfully hooked up and tested some servos by plugging into the PixHawk and using the servo's tab to toggle low and high PWM values. But when I try to do Script.SendRC(9, 1500, True), nothing happens. I have enabled passed through in the RC9_Function parameter list. I have everything wired correctly, I just don't see my error. Can anyone help me?
  • Hi,
    I am having the exact same problem. Have you found a fix? After a lot of searching the only thing I found people saying is that the aux rail does not provide the proper voltage but when I check it with a voltmeter is shows 5v. Let me know if you have any luck.
    Thank you,
    Malek E.
