Servo Selection?
Just wondering if anybody has noticed any improvement in stabilisation performance, particularly reduction of occilations with the use of High speed servos?
Cheers Paul
  • Paul,
    High speed servos may give a faster response time, but I don't think that they will cut down oscillations.
    Oscillations may be due to blow back, or using a servo that cannot push the control surface against
    the flow of wind. If this is the case, you can use a stronger servo (more lb/ft).
    If a wing has a weak design, the entire wing can rotate back and forth.
    Stephen
