I solder header for the 2 servos pan/tilt on the ardustation but it seem to me that the second one (the nearest from the edge of the board) is not connected to the PCB (well I didn't see any line like the one connecting the first one).
I am wrong? or should I make a bridge between the 2 +5V. I connect 2 servos and during the antenna  test only one works, I didn't have my multimeter for now so i can't check the voltage.
solved, a bad soldering pin on one of the servo connector, work very well now
