Set Flight Modes with Mavlink?
I am trying to figure out how to send commands through a serial connection to my IRIS+ to change the flight mode.
I changed the modes with the transmitter and captured the values for 'Base_Mode' and 'Custom_Mode' as reported by the Heartbeat packet.  I was seeing things like:
AltHold (quad disarmed): Base_Mode=81 , Custom_Mode=2
Loiter (quad disarmed): Base_Mode=89 , Custom_Mode=5
Auto (quad disarmed): Base_Mode=89 , Custom_Mode=3
RTL (quad disarmed): Base_Mode=89 , Custom_Mode=6
AltHold (quad armed): Base_Mode=209 , Custom_Mode=2
Loiter (quad armed): Base_Mode=217 , Custom_Mode=5
Auto (quad armed): Base_Mode=217 , Custom_Mode=3
RTL (quad armed): Base_Mode=217 , Custom_Mode=6
First, any idea what these Base_Mode values mean?
Second, how can i formulate a command to send to the quad to change the mode between AltHold/Loiter/Auto/Etc.?
I am using a C# application, so any code samples would be great.  Thanks!
    I'd suggest you implement saving a .tlog file in your C# app, then use mavlogdump.py to compare your tlog with one from a working GCS implementation. That should allow you to answer almost any question on how to implement functionality that is in an existing GCS
    Values for custom modes are listed here https://github.com/diydrones/ardupilot/blob/master/ArduCopter/defin...
    In c++ you can set the mode as so mavlink_msg_set_mode_pack(GCS_SYSTEM_ID, GCS_COMPONENT_ID, &msg, TARGET_SYSTEM_ID1, 1, customMode); just use 1 for the base mode it's ignored by the APM anyway
  • To be more specific, i can successfully ARM/DISARM the quad with the following:
    MAVLink.mavlink_command_long_t req = new MAVLink.mavlink_command_long_t();
    req.target_system = 1;
    req.target_component = 1;
    req.command = (ushort)MAVLink.MAV_CMD.COMPONENT_ARM_DISARM;
    req.param1 = armed ? 0 : 1;
    armed = !armed;
    byte[] packet = mavlink.GenerateMAVLinkPacket(MAVLink.MAVLINK_MSG_ID.COMMAND_LONG, req);
    serialPort1.Write(packet, 0, packet.Length);
    Now i thought to change flight modes like this, but it doesnt seem to be working:
    MAVLink.mavlink_set_mode_t req2 = new MAVLink.mavlink_set_mode_t();
    req2.target_system = 1;
    //req2.base_mode = 16; //BASE MODE = ?????
    req2.custom_mode = 5; //Loiter Mode
    byte[] packet = mavlink.GenerateMAVLinkPacket(MAVLink.MAVLINK_MSG_ID.SET_MODE, req2);
    Do i need to set the .base_mode parameter as well?  I dont know what the value should be for that, and as noted above, it seems like they change as i manually change modes with the transmitter switch and output the values on screen.
    Help?
