I can see that the initial setting of level is important in flight. Makes sence.
But how are you establishing that the craft is indeed at a level state?
I bought a "bulls eye" level and mounted it on the top deck of the craft and I lift and lower till its dead center, then set the level in the software.
Once set, do I need to set the craft in this manner prior to arming, prepping for flight?
Tags:
Permalink Reply by Anis Nielsen on September 17, 2011 at 11:40am Hi Julie ;
Im also new to this and did as you describe ; I assume after having leveled , you don't need to exactly position yur quad in the same levelling fashion for a take off and flight;
But i understand why you ask .. do your quad feel slightly unleveled ? .. i have the same feeling but i think just by adding a non-centered or slightly unbalanced lipo can move the CG elsewhere .. and that is what might be confusing
last night Ive spend 4h preparing , leveling etc .. and i still don't have a perfect still hover .. it always wants to get on a side, to the rear ..
But here is another aspect to take in account : Ground effect .. if you hover still but too low .. you cannot conclude that your craft is not correctly CG centered or incorrectly levelled .. it might only be ground effect. try higher :)
ps : also , ground types like not recently mowed grass parasites much less than plain simple concrete grounds; well that something i empirically noticed .. maybe i had my quad perfectly rigged that day ?
Permalink Reply by Anis Nielsen on September 17, 2011 at 11:57am one more thing : its the APM you want to be sure is level;
Permalink Reply by Julie Macfarlane on September 17, 2011 at 12:16pm I just back in from flying!
I agree with those points. I had forgotten about the battery until I landed on the roof of my car and the battery dropped out.
I have 3 batteries so I can swap quickly. I need something more than one velco strap to hold them in position.
Next steps:
Hot glue an ear bud cover over the barometer
Re-secure the batteries.
Think about adding sonar.
Then wait till the new props arrive because I just broke one..
Permalink Reply by Anis Nielsen on September 17, 2011 at 12:21pm ha! spare parts! ^^
may i ask : an ear bud cover over the baro .. why ?
Permalink Reply by Julie Macfarlane on September 17, 2011 at 1:17pm Slows air flow over the sensor causing fluctuations in the output.
Sort of like the spone foam over a microphone.
Permalink Reply by agmatthews on September 17, 2011 at 11:35pm Julie,
The AC2 software does a 'gyro' level the first time you arm the motors after each power up
You should have the aircraft level at this point
Andrew
Permalink Reply by Julie Macfarlane on September 18, 2011 at 3:33am Ok. I thought it did.
Im going to have to build a platform that can allow leveling prior to armimg then, as my drive way is any thing but level...
Thanks.
Permalink Reply by Heino R. Pull on September 18, 2011 at 7:36am
Permalink Reply by Anis Nielsen on September 18, 2011 at 11:46am thx Julie, thx Heino for the confirmations
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.692 members
51 members
186 members
1298 members
24 members
Powered by
