Hi everyone,
With the encouragement from Ellison in Rants and Raves thread, I'm creating this thread to share your drone/copter information. I believe, this would help immensely for newbies like me during the initial build. For example, the Chris's blog on cheap Hobby King quad configuration is really a good resource.
I don't want to burden anyone who is willing to share their info. Hence all fields are optional. Atleast the first 5 fields are ideal. Please find the list of fields to copy/paste at the end, so you can start filling :-).
Here goes information about my quad.
frame: Quadcopter (3DRobotics)
controller/autopilot: APM1
esc: 20A (3DRobotics)
motors: 850Kv (3DRobotics)
propellers: 10x47, APC (3DRobotics)
motor to motor distance: -- inches
battery:  4S 3300mAh (Turnigy nano-tech)
total weight: -- lbs
flying time: 15 minutes (average)
radio: Turnigy 9X
video/osd: none
other: Sonar, Xbee, GPS/Mag, Attopilot current sensor
Misc:
Turnigy 9X: Mode1 -> Mode2 change, Li-ion battery hack
photos:
frame:
esc:
motors:
propellers:
battery:
flying time:
radio:
video/osd:
other:
Misc (hacks/mods):
photos:
This is cool indeed. By any chance do you have a video?
Also do you have any diagrams you would share?
I'm new to this forum... I'm not sure if you're replying to me or not.
It's on my To-Do list... past couple weeks have been kind of busy. I'll probably find time to re-tune my control system and get a video up by this weekend.
I didn't put together extensive documentation. If you (or anyone else) have any specific questions, I'll gladly answer and/or draw up a diagram if necessary.
I was replying to you Justin. Well, It'll be great if you can describe a bit of your controller? most of the controllers in this thread is APM1 or APM2. I see you are using a different one. A small, rough diagram would be great! :-)
regards,
Ruwan.
I think I can accommodate that... It's not horribly complex.
Thanks Justin!
Hello,
Few weeks ago, I got my Purple APM2. As I had an Y6 project for FPV and Cam work, I worked on a personal custom frame.
Latest design with a VTail flew today. Classic Y6 was fine (still struggling with PID settings but after discovering that I have to set Acro before Level all is quite OK now) but I developed VTails for my Quads (MultiWii), I wanted to experiment the formula on Y6.
So here is some data and pictures:
frame: Custom VTail Y6 - lenght from center to motor is 11"
controller: APM2
motors: KDA A20-22L
esc: Turnigy 25A
propellers: APC 10x4.7
battery: 2 Lipo 3S/2200or 2600mA
weight 1680g
Flying time: 10mn
radio: Futaba Fasst
Misc: Motor placement is altered: CCW 1 is TOP, CW 5 is BOTTOM
CCW 6 is Right VTail, CW 4 is Left VTail
Frame can accept 11" propellers.
Photos
http://www.flickr.com/photos/80748892@N00/6937301426/in/photostream
http://www.flickr.com/photos/80748892@N00/6937301474/in/photostream
http://www.flickr.com/photos/80748892@N00/6937301594/in/photostream
http://www.flickr.com/photos/80748892@N00/7083377613/in/photostream
Just an update with live photos
Nice. Went through your flickr stream as well. Couple of questions, Do you have different configurations, or are they iterations of this? What is the angle of V in V-Tail?
BTW, love to see a video if available.
Thanks,
Ruwan.
Hello,
VTail angle is 120°. Yaw is snappy with it.
Should fly it indoor tonight and make a video.
I have also two Quads.
Small one (700g) with 8" props with an Inverted VTail (140°) and a larger one (1060g) with a normal VTail (120°) and 10" props, the same parts as the Y6 presented.
Smal Quad is Paris v4 Sirius board. It is my first VTail.
Large Quad is with Paris v4 and FreeIMU 4.3. I had some work in progress with the Z-Hold PID with it.
MLB
Video is in progress
Indoor flight. Mostly in Stable mode.
MLB
Hi Marc
I bought the Hunter Vtail frame :http://vizionair.fr/droneshop/fr/droneshop/433-dialfonzo-hunter-vta...
They claim that you need either a Vtail  Or Y4 mode (Multiwii FC) do you think that it could work with the APM2  without entering into the code ? I am not an expert in programming !!
Regards
Jean Louis
