Hi everyone,
With the encouragement from Ellison in Rants and Raves thread, I'm creating this thread to share your drone/copter information. I believe, this would help immensely for newbies like me during the initial build. For example, the Chris's blog on cheap Hobby King quad configuration is really a good resource.
I don't want to burden anyone who is willing to share their info. Hence all fields are optional. Atleast the first 5 fields are ideal. Please find the list of fields to copy/paste at the end, so you can start filling :-).
Here goes information about my quad.
frame: Quadcopter (3DRobotics)
controller/autopilot: APM1
esc: 20A (3DRobotics)
motors: 850Kv (3DRobotics)
propellers: 10x47, APC (3DRobotics)
motor to motor distance: -- inches
battery:  4S 3300mAh (Turnigy nano-tech)
total weight: -- lbs
flying time: 15 minutes (average)
radio: Turnigy 9X
video/osd: none
other: Sonar, Xbee, GPS/Mag, Attopilot current sensor
Misc:
Turnigy 9X: Mode1 -> Mode2 change, Li-ion battery hack
photos:
frame:
esc:
motors:
propellers:
battery:
flying time:
radio:
video/osd:
other:
Misc (hacks/mods):
photos:
Hi
I'm new to this forum and this seems to be the ideal place to start.  Just finished my quad (first build) and have had it up and flying.  Very stable from the get go and I think this has a lot to do with spending adequate time and attention to detail during the build process.
My specs:
Frame:  Own creation
Controller/autopilot:  APM1
Motors:  E-flite 480's 910kv
Esc:  E-flite  Pro 40amp
Propellers:  12x4.7
Battery: 3s 3300mah
Flying time:  approx. 10 mins
Radio: JR xg7 2.4ghz
Video/OSD:  None
Can anyone tell me how the aluminium protective dome might affect the 2.4ghz signal?   I haven't flown it out far enough yet since I'm still learning to fly it properly.
My name is James and I am new to UAV's.  I had a previous post, but since I made many changes to my drone I decided to post again with new pictures.  I purchased my drone from FPVpilot.com and for the most part I love it.  I changed the booms from C section to square tubing (with rubber grommets between the boom and main frame), mounted the motors using X mounts dampened with neoprene rubber washers, changed the landing gears for something of my own design using 3/4" aluminum flat bars (hand bent to V shape and dampened).
Frame: FPVpilot.com (with some modifications)
Autopilot: APM 2 purple complete
Motors: RC Timer BC2836 880 kv
ESC: RC Timer 30 amp programmable
Props:  APC 10 X 4.7 Slow Flyer
Battery: Sky 4s 5000mAh (2 in parallel)
Flight Time: 20 minutes (3.6v low)
Radio: Futaba 7c 2.4 ghz
Cameras: Gopro HD2 and Tachyon Ops (rear facing)
Here's a link to view my hexahere
That is a very impressive hexa. That 20 min flight time is superb for an amateur multicopter.
I have a few questions:
How heavy is your hexa including the two batteries?
Do you know how much payload capacity it has?
Also, do you happen to know around how much thrust each motor puts out at full power?
I'm trying to build a quadcopter for FPV with a decent flight time. I'm aiming for 15min+
Thank You
frame: 3dr-b
controller/autopilot: APM 2, external GPS
motors: diydrones 880kv
esc: diydrones 20A
propellers:APC 11*4.7
battery: Zippy LiFe 4200 3s / 4s
flying time: 11min
radio: Spektrum DX8
video/osd: none yet
other: sonar, optical flow, 3dr radio
Misc (hacks/mods): wooden mounts for sonar & optical flow, led strips, fluorescent swimmers as orientation indicators.
weight: 1169 grams plain, 1600 grams with 3s LiFe, 1700 grams with 4s LiFe
photos:
Upgrades!
Quad --> OctoQuad
Modded ESC's on a distro board with Attopilot 180A current board.
The splash screen on my TX
APM Mods - see the extra cap next to the ADC chip for the sonar, and the breakout for the outputs needed for an octo.
Frame: Custom
Controller: APM1
Motors: JDrones 880kv
ESC's: Flashed JDrones 30A
Props:  12" x 4.7"
Battery: 4s 5500mah
TX: Eurgle 9x running ER9x with FrSky telemtry
Video: 540TVL Camera 5.8ghz 600mw TX
Extra's: Sonar, Optical Flow, Xbee, GPS, Mag, Atto Pilot
Board modded to filter sonar better and easy connection of outputs 7 and 8
Weight: 1700g without battery, 2230g with 4s 5500mah
Other Stuff: Ardustation
I haven't posted here often, but I thought it would be fun to share info on my quad.  First, the obligatory:
frame: My own quad frame + electronics enclosure.
motors: 880kv
esc: 18A (Turnigy Basic)
propellers: 10x4.7
battery:  3S 4000mAh
flying time: ~9Min
weight: 4.1 lbs
radio: Hitec Aurora
video/osd: GoPro, minimosd, 5.8Ghz Fatshark transmitter, Fatshark dominator goggles (All removed in the most recent pictures for basic testing)
other: Sonar, Xbee, GPS/Mag  (All removed in the most recent pictures for basic testing)
Front picture (that is a custom go-pro mount hanging from the front)
Rear:  Notice the sonar.
Enclosure:
The arms and core structure (which fastens the arms) were milled out of 6061 alum.  After destroying several other frames, I wanted something sturdy that I could learn on.  This most recent one has survived 20+ *very* hard landings without issue.
The electronics enclosure is the fourth enclosure, but only the third printed variation.  It holds the receiver, apm1, and gps.  The top is laser cut (so that I can see LEDs easily).  The holes that you see are there for fastening the xbee and video transmitter to the top.  I need a good enclosure for those, but haven't undertaken that yet.
The battery + sonar mount is PLA printed on my reprap.  After having an incident where the batter slipped out of the velcro straps in flight, this one has a 6mm lip that holds the battery from shifting while the velcro holds it snug.  There is a box that holds and protects the sonar itself from damage which is attached to the sonar mount.
The gopro mount is printed PLA as well.  It holds the go-pro very well and you can see in the videos how vibration free/smooth the it is.
All of the parts were designed in cad programs and milled/printed/lasercut on CNC machines.  I'm very pleased with the result.  If anyone would like to see some pictures of the previous frames, enclosures, or process I'd be happy to share in a reply.  See the video links below (and excuse the beginner flying).
Most recent manual flight: http://www.youtube.com/watch?v=QuEyrV_vmXA
2.6 loiter mode test: http://www.youtube.com/watch?v=y2mPJFdtJoQ
Old flights ...
http://www.youtube.com/watch?v=BfpZ7KhP0bA
http://www.youtube.com/watch?v=CmYXIfc3pb4
http://www.youtube.com/watch?v=NNPMosfk9Ws
http://www.youtube.com/watch?v=XZNYr9neA4Q
You can visit my profile for some pics of a few of my quad designs. Didn't want to put too much on a post. So far they have all shared the same gear and weight range, or close enough. Designs are with sport flying in mind, being able to roll and flip. Although the thrust/weight should offer a decent payload, no tests or design accomidations have been made.
I have an APM2 on order and am looking forward to getting the latest version quad to maiden on my new controller!!!
more about specific versions here as well.
frame: my own designs
controller/autopilot: KK v5.5 (different "brands")
motors: eMax GT 2205 -1660kv
esc: Hobbywing 12A
propellers: 8 x4.3 SF
battery: 1800 2s 30c or 1800 3s 30c
weight: 14-16.5oz depending on frame and cell count
flying time: 14-18min depends on stunts or just flying
Can you give the weight sizing as well?  Thank.
That is a good idea, let me add it to the original post.
frame:  Personal monstrous design.  3/4 Aluminum tubing
controller/autopilot:  APM2
esc:  Turnigy Plush 60A
motors:  E-Flite Power 32 770kV
propellers:  APC 13x4 Electric
motor to motor distance: 36 inches
battery:  Turnigy 20-30C 4S 5000 mAh
total weight: ~8 lbs
flying time:  Wouldn't know.  Can't fly it for more than 30 secs before crashing
radio:  E-Flite LP5DSM
other:  Lots of Zip-Ties that seem to come off at the wrong times
Misc (hacks/mods):  Carefully crafted StarBucks Directional Indicator
photos:
I think I may have built this thing waaaay too big and heavy.  Can't seem to tune the PID to keep it steady.  Constantly have to fight it to keep it somewhat leveled, otherwise it draws blood.  Anyone have any ideas?
You might want to try two things to improve handling:
-Move the ESCs further away from the APM. They might give you some sensor interference in flight.
-Mount the APM directly to the frame, with Velcro or nylon stand-offs. It looks like the suspended mount might give you more vibration instead of dampening them.
