How can you go about adding a debug statement to the ArduPilot code. I made some changes and wanted to log or print to screen during SITL testing.
Will the Serial.print work anywhere I put it without breaking something?
Or is there something already built into the code I can call or use?
Thanks,
-Matt
Tags: APM, Debug, Help, Software
Hi Matt,
Serial.printf() will work almost everywhere (the exception is places like interrupt handlers).
If you only want the message in SITL, then you can instead use SITL_debug(), like this:
  SITL_debug("some message\n");
Cheers, Tridge
Hi Matt,
I have used Serial.print ('' ") for debugging quite a bit. Just pit it in a slow loop so you can read it and the digits don't flicker, and comment out other prints as needed. Like here at the end of the fast loop.
    set_servos();
///test///    gcs_update();
///test///    gcs_data_stream_send();
static void medium_loop()
Add you stuff to the medium or slow loop.
Andrew I'm a bit confuse.
I wrote this code (bits of Test code) in ArduPlane:
case 4:
medium_loopCounter = 0;
delta_ms_medium_loop = millis() - medium_loopTimer;
medium_loopTimer = millis();
if (g.battery_monitoring != 0){
read_battery();
//****Test Code
SITL_debug("Sitl:Hey!\n");
Serial.print ("Serial:Hey!\n");
//****End Test Code
slow_loop();
break;
I do see "Serial:Hey!"....  in APM console but not the SITL one...
maybe I missed something.... please help.
Cheers,
-Eric
Thanks, for all the replies definately helped a ton.
I tired to go the route of writing my own flash log outputs in the Log.pde, just glad to know there is an easier way.
Thanks!
