Hi All,
I'm using mission planner to connect to APM 1.4 through a FTDI cable[1]. When I do that, I can install the Quad HIL version. But when I tried to "Connect", I get the "No Heartbeat Packet Received".
Once I use a normal USB cable through IMU to connect to the same APM 1.4, I can connect without an issue.
Would this be a result of a bad FTDI cable? What puzzles me is that installs the firmware without an issue..
Thanks,
Ruwan.
I also tried checking/unchecking the reset apm on connect option with no success.
