SITL and X-plane 10
I have been trying to use X-plane 10 and SITL.
I first followed step by step those 2
tutorials http://ardupilot.org/dev/docs/sitl-native-on-windows.html
http://ardupilot.org/dev/docs/sitl-with-xplane.html
Then I installed mission planner (latest version)
When I try to connect mission planner to X-plane I don't get any X-plane option, just a map.
Is there something I missed?
(the first file shows what I see the second is what I am supposed to see.)
any help would be appreciated
chris
  • Thank you for your reply,
    When I click on the plane or any other icons I get after a connection try the following message:
    C:/users/chris/documents/missionplanner/sitl/cyggcc_s-1.dll Is either not designed to run on windows or it contains an error.try installing the program again using the original installation...
  • Just click on the plane icon bottom left and the sitl code will load automatically for you, make sure your virus ware doesn't block it.
    The code has overtaken the instructions in the wiki I think.
