I've just about got my Arducopter Quad (with the APM 1 board set) ready to fly...
I can connect with the MavLink... have the ESC's calibrated, and motors turning in the correct direction.I can see the radio control inputs in the software set-up.... everything seems ready to go.
But when I disconnect the MavLink, and the USB cable.... I no longer have RC control of the copter.
Is there something I am missing about saving settings... or disconnecting from the USB? If I can't figure this out, I'm going to be searching for a very long USB cable... :-)
Thanks!
-Taylor
Tags:
Could it be simply the way you power your RX?
Permalink Reply by Taylor Collins on April 25, 2012 at 12:40pm The receiver is running off a BEC from the copter. The radio will not function (with.. or without the USB connected) unless the 3 cell LiPo is also connected....
Permalink Reply by Taylor Collins on April 28, 2012 at 12:18pm It turns out that it was the lack of a solder jumper on the tiny SJ1 bridge.... one dab of solder, and now the board is powered... with or without the USB connection.
Thanks for the help!
Taylor: your board should have arrived with a removable jumper already in place on the SJ1 pins. Wasn't that the case? If not, when did you get it? Some of the earliest boards didn't have those, but the last thousand or so should have all come like that.
Whoops, sorry. I see you've got an APM1 board. Never mind!
Permalink Reply by Taylor Collins on April 29, 2012 at 5:52am Chris,
Thanks for your concern. I bought this Quad Arducopter "second hand" from a fellow on the Runryder forum. It was new, never flown... but previously owned....
-Taylor
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.183 members
47 members
692 members
51 members
186 members
Powered by
