Solid Green and Solid Red
One of my radio's is solid green and the other is blinking green.  I can't connect to either.  I tried to set the solid green in bootloader mode but it doesn't go.
Not sure where to go for help.
WinXP
Mission Planner 1.1.86
3DR 433mhz
Both comm port and MP set to 57K.  New drivers installed for the usb.
If I try to load settings I get "Failed to enter Command Mode".  If I try to update the firmware I get "Failed to identify Radio"
Update:
Tested on a different computer and still no connection.  Now one is solid Red and the other is solid Green both can't connect to MP.
-----3690935558?profile=original
Just had it connect using the 3DR Radio Config tool.  I was in the middle of "programming" loading on the radio and then the sync failed.
Attached is the error message from MP.
One radio solid green the other solid red.  Attached is the 3RRradio.log
Any ideas?
Thanks in advance,
Matt
3DRRadio.log
  • Same problem to me:
    One is ok (blinking green) I can conect with mission planner
    Other is solid green and red blinking, I can not conect by Mission planner and I can not enter int program mode :(
  • Matt,
    Hi. Any news about your radios?
    Serg
