I have developed an algorithm in matlab to control the 3dr solo drone from PC. Is tit possible to control the drone from my matlab model. I would like to control the drone by certain commands like takeoff  and return home. Could you please help me in interfacing my matlab model with 3 dr solo drone. My idea is that i can interface matlab model with UDP blocket and establish communication between Drone and matlab model via WIFI to the UDP port of Drone
using the WIFI method we can only communicate with the drone for small distance only
Have you successfully done it?
This is not true wifi can be boosted over a long range, you need a booster module for your wifi antenna! it is 100 possible I have done this meany times with this platform. there is also documentation on this .
