Trying to correct the measurement what I am getting from 1260MB. When i measured I found out that the sonar was giving 36cm against a distance from ground of one meter. Guide me if this function is responsible for range calculation in AP_RangeFinder_SharpGP2Y.h
int convert_raw_to_distance(int _raw_value)
if( _raw_value == 0 )
return max_distance;
else
return 14500/_raw_value;
If it is so then what is 14500 thing how did it come. If I can find out this then I can apply the correction to get the real value.
While measuring this I am just using CLI and APM is not connected to any motor.
Tags:
Permalink Reply by Michael Pursifull on October 17, 2011 at 12:19pm I didn't mention this at the time, but I would focus even more on the 20-30cm range to get a more accurate reading there, then test that out to 700cm or so. I'm not sure if you will find 1.4 as ideal. There are a range of other formulas which might be more accurate, but I suppose you only need it just so accurate...
As I said in the other thread on this, I wanted to do more testing, especially in the 20-30 cm range, but haven't found the time. So many wonderful things to work on. But I hope this discussion was helpful...
Permalink Reply by agmatthews on October 30, 2011 at 7:21am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1298 members
87 members
693 members
7 members
48 members
Powered by
