Spin on / quick release / self locking prop adapters?
More and more RTF 'çopters are coming out with spin on prop adapters or even spin on props (DJI, et al).
The idea is no nuts or other tightening methods, the prop adapter spins onto the threaded shaft and self tightens due to the rotation of the motor.
http://www.himodel.com/multi_rotors/Quick_Release_Prop_Adaptor_Set_for_Multi-copter_4pcs.html
http://www.ebay.com/itm/Brushless-Motor-CW-Aluminum-CNCPropeller-Mount-Holder-Fixture-Clip-red-ge-/261665476276?
Can one use standard props (APC slowfly, etc) with these or do you need the carbon flat-center props?
Are there any that are designed for standard props?
