Spraying Drone Chargers - SkyRC PC1080
3691334176?profile=original
UAV spraying becomes hot here in China.
SkyRC PC1080 is a dual channel charger, which can charge 2 pack of 6s LiPo batteries at the same time. what's more, the charger is equipped with master-slave control mode, which allows you to synchronize more than one charger when charging same batteries.
3691334373?profile=original3691334201?profile=original
Dimension  272x202x118.6mm
Net Weight  4.88kg
Input Voltage  100-240V
Output Power  1080W (540W x 2)
Discharge Power  100W (50W x 2)
Charge Current  1.0-20.0A x 2
Balance Current  1.2A
Battery Type  LiPo/LiHV
Battery Cell Count  6S x 2
Working Mode  Balance Charge Mode
                         Storage Mode
                         Charge Mode
Certificate CE/FCC
3691334190?profile=original
