Hi -- I want my plane to be able to dive steeply. So if I set a waypoint at 5000 ft, and another very close by at 2000 ft, it will dive steeply to reach the second point at 2000 ft. What do I need to change in the parameters to make this happen? Thanks!
Tags: dive, parameters, steep
Try 'Pitch Min' to something like -60 (or more) and set 'ALT_CTRL_ALG' to 1. That will tend to use the elevator more, and essentially puts ArduPlane into altitude priority mode, as opposed to airspeed priority.
Don't pull the wings off when you pull out :)
For now, I'm only simming, so not yet worried about G-forces...  ;-)
Sounds great -- I'll try it once I get my other sitch fixed --
see my other post of today about gyros...
Thanks!!!
--Prahas
Dive commands worked great!  You should have seen the wings warble...  ;-)
FYI -- the command is "Lim_Pitch_Min" ...
Thanks again!
--David
