steer 2 servo VS. heading 2 steer
I'm trying to help a friend setup a rover (really a hovercraft). Please help me understand the diffence between steer 2 servo and heading 2 steer settings.
Are they two nested PIDS? when setting them what is each used for?
Thank you, I can't find any documentation on steer 2 servo.
Jonathan
  • Admin
    @Jonathan,
    You must have a very old version of the ArduRover2 firmware?
    The latest versions of the ArduRover2 firmware (L1) no longer make use of the heading 2 steer parameter.
    I suggest that you use ArduRover2 stable version 2.45 or later beta versions found here: Link.
    Rover tuning instructions can be found here: ArduRover Wiki
    The Full Parameter List, found in the MP under the Config/Tuning Tab (Advanced View) generally has explanations of the ArduRover parameters.
    TCIII ArduRover2 Developer
