Hi, I`m going crazy.
My Hexa didn´t work well and I recalibrated accelerometers, transmiter, etc, etc. I checked the motors and everything was well but the Hexa didn`t work well.
I have a strange problem with the motor output number 8.
If I connect this motor to Ardupilot, this has not force but if I connect this motor another receiver this works very well.
I have disconnected every motors less number 8 and this has not force, I thought the motor was brned but when I have connected it another receiver it works perfectly.
The Hexa has been flying perfectly with Ardu Pirates and Arducopter 2.0.17 and now it does not work well.
I have not changed hardware or anything.
What could it be?
Thanks.
Tags:
According to Ardupilot Mega Schematics v 1.2, PWM Outputs 7 and 8 do comes from PE5 and PE4 AVR Mega outputs.
PWM Outputs 1 to 4 do come from the multiplexer circuit 74LS157.
Port E on AVR Mega does not have high driving capabilities. Only port B has high current outputs. It is possible that PE4 and PE5 AVR outputs do not have enough drive capability for your ESC.
Or you could have a problem on your AVR Mega chip, or a short on this output with an adjacent wire, or a bad solder somewhere.
Eventually a problem on the ESC input (too low impedance). Did you try another ESC ? A too low impedance input on your ESC could work on a receiver output, but not on the port E AVR output.
Last, could be a problem in the code, but this is less probable.
If i remember a discussion i had a few weeks ago a Ardupirate developper has reported that some AVR outputs could become wrong after overloading.
If you can put a scope on this output and compare with other outputs, you will get your answer. if you see a distorded signal, then you have a hardware problem. If you see only bad pulse timings, then it's probably a software problem.
I would vote for the hardware problem with 75 % confidence.
Thanks for your answer. I think like you, it`s a hardware problem.
I have reviewed all the welds and connectios and are ok.I fear it´s the Ardupilot.
All outputs work well under the 8.
Can I change the output number 8 by 10? Or is labor?
Has this happened to anyone?
Thanks.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
83 members
24 members
682 members
1288 members
Powered by
