This is a thread to submit ArduCopter configuration files (PID settings) for common airframes. Once they are reviewed, they will be placed in the manual here so that others may use them.
Along with your config file (saved from the Mission Planner), please list:
Tags:
Permalink Reply by Oliver on February 23, 2012 at 9:34am Gaui 330X Quad APM2 in X config:
Factory Motors (1050Kv) and factory props (8 inch), 2200mAh 3S mounted below
Flight Weight: approx. 600g, Time: 14-18 mins
Stab P: 8.3 (8.5 for aggressive)
Rate P: 0.19 (2.0 for aggressive)
Others default (need to find time for more testing, but defaults do ok for Loiter, Auto, Baro Alt Hold)
Permalink Reply by Jason on March 10, 2012 at 5:07pm Nice Oliver!
Now, if we can just get a few more here!
Hey Jani, how about posting some good hexa PID's.
I'll try to do one here as well as soon as I can stop crashing it into the ground from wobbling.
Permalink Reply by Ian forbes on March 10, 2012 at 6:59pm Nice this is exactly "what we who are newbish" or flying new configurations needed, might save people a few bucks on propellers:). I think most can tweak the fine PID settings a little, but need a good flyable benchmark to start wth. Can we post requests for frames configurations here as well here too?
Permalink Reply by Jason on March 13, 2012 at 6:37pm Yes it would be good! Give us a great place to start comparing settings etc... and it would also help to teach some about the coding itself. I have a Jdrones Hexa Heavy lift model, support is nil, which is fine, just need a good starting point instead of going to 80 different threads about using different model's instructions and trying to interpolate what you should do. Being grumpy doesn't help, but sometimes the best course of action is to try another platform that has more support first, and then, if it's worth it come back to this setup.
Permalink Reply by Ian forbes on March 13, 2012 at 11:24pm @Jason--> Support is nil, you mean on APM 2 board with regards to settings or in general??
Permalink Reply by Jason on March 14, 2012 at 3:44am No Ian... on certain models, yet some of us are still unlucky enough to have APM 2 =)
But this most likely isn't the forum for that, just a comment on my experience thus far.
Permalink Reply by philip desborough on April 8, 2012 at 9:08am i am working on the 3dr hexa
Permalink Reply by Randall Richmond on April 10, 2012 at 9:46pm What version APM are you using?
Permalink Reply by philip desborough on April 11, 2012 at 10:08am i have APM 1, GPS, Magnetmeter, Sonar, XBee, Mini OSD, 30Amp ESC, 880Kv motors,12x45 props
ImmersionRC 5.8GHz Diversity Receiver, ImmersionRC Long Range Transmitter,5.8GHz Cloverleaf Antenna, 5.8GHz Skew Planar Wheel Antenna, 7dBi Circular Polarised Panel Antenna for 5.8GHz
so far and adding a Gimble
i hope to run it from 3s battreys
I have very similar setup. Same 880kv motors and 12x4.5 props. What PIDs did you have to change to make up for the difference from the normal 3DR 850kv 10" props? I saw to reduce the Rate_P to .90 or so. Just curious what else you had to change... Thanks.
Permalink Reply by Alex on May 19, 2012 at 9:19pm Tricopter running 2.5.5
DIY but similar to RCExplorer.se design, 1.8 to 2.3 lbs flying weight, 18" arms, 3s battery
DT750 motors
Gemfan 11x4.7 props (from Hobbyking), front are counter rotating
APM2
Loiter, Nav is NOT tuned but Alt Hold, roll, pitch, and yaw are. The yaw is not perfect but it is the best I could get it after lots of fiddling. The Yaw D does not work on a tri, in 2.5.5, it causes instability so until that gets fixed we are stuck with mediocre yaw performance.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.186 members
1298 members
24 members
51 members
51 members
Powered by
