hello
i've just samshed my Arducopter :
fliying with the latest and greatest code : everthing well.
hoovering around a bit but suddenly the Arducopter flipped to his back and crashed to the ground.....
everythin with my 2.4 GHZ rec 7 Trans is ok.
any idea ? or is it stlii too much " BETA " ?
Tags:
Permalink Reply by Chris Lovett on April 29, 2012 at 10:02pm Yes it did solve the problem. I'm switching to a different connector from now on, but if you have bullet connectors a dab of solder is enough to tighten the joint so it doesn't slip during flight.
Permalink Reply by Chris Lovett on April 29, 2012 at 10:06pm My son also designed a new carbon fiber frame which protects the blades, so it is not much more robust against crashing into things. Saved a lot of money on spare parts already. See http://www.lovettsoftware.com/images/CarbonFrame.jpg
Chris,
your son's quad design looks very interesting, since I am a beginner in RC. Does the frame fly well? Any video on the net?
Lars
Permalink Reply by Chris Lovett on April 30, 2012 at 1:40pm It flies really well. The carbon fiber is very light so it is quite agile. The extra surface area does catch the wind a bit more, but the protection for the blades is worth it.
Thanks for the information. My hexa+ consumes props because I am still go down so fast that it bounces and flip.
Lars
Bullet connectors are electrically some of the best connectors our there, if you stay away from the swivel crap some manufacturers have started with. A real bullet connector should be a solid piece of metal. Like for example this.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
Permalink Reply by Chris Lovett on April 30, 2012 at 1:38pm Those do indeed look much better than the ones I have, I just ordered some to try them out.
I usually also take a flat screwdriver and bend the connection arms out slightly more, so that the connector is really tight when you connect it (to the point that you have to struggle a bit to insert it).
Permalink Reply by James Y. on May 1, 2012 at 12:03am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.183 members
1283 members
24 members
180 members
4 members
Powered by
