Hi, just trying to set up my apm, but I have no control of the servos with the motor not running, does that mean that I can´t land the plane without the motor running?,, I´m flying a wing with no landing gear, ,the prop will always hit hard on the ground.
Please assist.
  • Looks like the APM has the ADuCopter firmware installed. Hence the system said "Alt. Mode".
    Just a thought... I would attempt to re install the Arduplane firmware and see what happens.
    • Ardupilot 2.5
      throttle failsafe disabled
      ardupilot powered with esc cable lead
      servos connected to apm directly
      jp1 connector inside the case
      the receiver is a FrSky D6FR
      The Alt Mode in the taranis is a voice added only,, not sent by the apm.
      Thanks all for your thoughts.
  • hi , ,thanks for your help,,, it means that I can only move the servos that control the elevons when I have the brushless motor running,, this happens in manual mode and fbwa mode.
    Another issue,  I have low throws on the servos to pitch up and down in fbwa, on manual they are fine. I tried increasing mixing gain to 1 and no changes.
    Sorry english is not my first language.
    • That is very strange indeed! I think you should make a video showing us what you mean. Post it on YouTube and put a link here.
      The other issue is simple. Your P gains need to be increased. Just use the new autotune feature.
