Anyone investigated or heard of this airframe? Found at www.thewingsmaker.com
It looks similar to the skywalker in terms of a pusher T-tail foamy, but it has larger wingspan, single center motorglider ground wheel and little tailwheel for self-launching, and looks like a wider payload bay, for $124/Kit to $220/ARF.
I really like the skywalker, but this looks like it might solve some limitations on it, specifically the wider cabin for photo gear, more payload?, and center wheel for both ground takeoffs and protecting a vertical camera. Skywalker wing area 35.5 dcsq vs. 43 dcsq for ogar.
I don't have much experience with airframes, so if anyone has some reports or observations, please comment.
Tags: skywalker
Payload bay looks cavernous... EPO construction...may be worth a try.
The tri-blade folding prop is a nice touch.
I have also been looking for a slightly larger airframe.  This is a step in the right direction, but it seems marginally powered to me.  With a 2830 motor and a 20 amp ESC I don't think it would get off the ground once it is loaded with gear.
Another new airframe (flying wing type) is on crashtesthobby.com    But I am not sure if the APM would handle the unusual elevator/elevon setup.
I have this fear that I will order the best available reasonably priced airframe and the next day someone will announce the perfect one I have been looking for.
John, very interesting link, I am guessing you were pointing out the Hercules airframe? The youtube video shows a rough crash with little damage. The OGAR manual show an option for a larger engine, I would probably go with the kit not the ARF and use a larger engine.
Very interesting link, haven't seen the Hercules before, a very impressive payload, especially on the extended version.
The flying wing configuration seems to be a lot more robust, the OGAR looks particularly vulnerable to damage to the rear half of the fuselage.
What sort of payload can OGAR carry?
Also in the equation is stability, I suspect that the flying wing has the upper hand here too, downside though is the high cost of Hercules.
Another supplier with a few nice airframes is FPVhobby.com  I especially like the 2 meter "big boy"  It is $329 for airframe only.  But I like the size and shape.  I may end up building something like it, when I have more time.
Did anyone try this airframe, just noticed this thread!
Its very pretty and that's good enough for me!
I have one waiting at the house http://www.rcgroups.com/forums/showthread.php?t=1477046  this site shows both ogar and SW ogar has a lot more room
Been flying this for some time.  I love it as it has a large aspect ratio. Surprisingly the 2830 motor carries the plane and a load quite well.  The cargo area is very spacious.  Bought this after losing a Skywalker hoping it to be comparable replacement.  I prefer it over the Skywalker.  The parameters I have been using are attached and tested well with all modes.  They were used with tested with ArduPlane-2.68.
