Awesome Aerial Photography System! Optimally configured, all the best components to create an awesome aerial platform! Ready to Fly!
Pick your package with the added options - or, go frame only!
Take your aerial imaging to a new level! Tarot 680Pro Hexacopter/Multirotor (UAV/Drone) with extended arms for heavier lifting power! This is the result of combining all the best components available to build a pro aerial photography platform!
This is an excellent system to use with Mirrorless cameras like the Sony A6000, Sony NEX, Panasonic GH4 or similar series cameras (camera NOT included!). Includes the wiring for a Sony A6000 (and NEX-5) - just drop the camera on the gimbal and you are ready to go! Includes complete FPV system, including the camera video link to the DJI Mini iOSD, Immersion 5.8GHz transmitter antenna to the monitor with built in receiver!
This version of the 680Pro has extended arms that allow for 15" props vs the standard kit with 13" props (stock build is a 685mm frame). This is effectively a 800mm frame - this measures 31.5" or 800mm from motor hub to motor hub. This stands 16"/405mm high (not including foldable GPS/Compass mast). This is not a stock configuration, it has all the best components configured together to make for a solid, stable & reliable photography platform.
This has been an amazing system and has helped me produce some awesome images - high quality images used commercially for magazine ads, TV ads, corporate websites, etc as well as large format prints sold in galleries! Step up your game! :)
Currently using a quad? GoPro? This is a great step, comparable with a DJI S800/S900 platform - similarly configured, these run 5-10k, this is much more cost effective! Why fly this system? So you can carry a high quality camera to create the best images possible!
Any questions on this system, contact me!
Tarot 680 Pro Extended Frame! Ready to Fly! Awesome aerial platform.
Personally, I used this with a Sony A6000 (with gimbal option below) and it has been a spectacular photography system. Now, I'm looking to downsize my fleet! See the other options below.
Here are the details…
Tarot 680 Pro Extended - 800mm frame
T-Motor MN3510/630kv Motors
T-Motor 40A Electronic Speed Controllers
Tarot High Efficiency Carbon Fiber Propellers 15"x5.5 (Full set plus a spare CW/CCW)
DJI Mini iOSD for FPV
DJI Naza-M V2 Flight Control System
Immersion 600mW 5.8GHz Transmitter
Retractable Landing Gear
IBCrazy Blue Beam Ultra 5.8GHz Antenna
Multistar 16000mAh 4S Battery (x3)
Multistar 10000mAh 4S Battery (x2)
As listed above: 1200.00 + 20 shipping (split shipping costs!).
This is NOT a traditional/stock 680Pro that you will see online, this is going to have substantially increased flight time, payload capacity and stability with the best motors/esc/prop combination you can put on this frame! It's awesome!
Options that can be added (contact me for details), when purchased at the same time as the Tarot 680Pro frame above. Just to note, these options are not included with the above sale/listing, these are separate options that we can add above and beyond to fully complement this photo rig. Buy it all and it's installed and ready to go - there is nothing more you would need (except for a computer to process photos/video!). Please feel free to contact me with any questions or photos of the components listed below.
40.00
HDMI to AV Converter Cable for Sony A5000 A6000 cameras
HDMI to AV Converter Cable for NEX-5
Flytron IR Shutter Release for Sony A6000 series
625.00
Grouse House Technologies GHT NEXt Gimbal V3 with Lightweight 2 axis mount
59/10 Grommet & Damper Interface
Simple BGC 32-bit gimbal controller
(Gimbal used on one flight - it's new! Works with Sony NEX & A6X00 Series, Panasonic GH4 and other mirrorless cameras)
290.00
Futaba 10JH 10 Channel Radio
Two Futaba R3008SB Receivers (x2)
190.00
Flysight Black Pearl 7" Monitor with built in receiver PLUS spare battery & AC Adapter
IBCrazy 5.8GHz Helical Antenna (x2)
165.00
iCharger 206B - Awesome battery charger!
Junsi 350w Power Supply
** Camera not included **
3691331784?profile=original
3691331744?profile=original
3691331797?profile=original
3691331815?profile=original
3691331546?profile=original
3691331871?profile=original
3691331828?profile=original
3691331899?profile=original
  • Sure! Feel free to ask here or send me a direct message. Thanks.
    Proptology said:
    Hey great read.
    Wondering if I could ask you for some advice?
    Tarot 680Pro Extended Hexacopter! RTF! Great Pro Aerial Photography System! Great Lifter! 1250.00
    Awesome Aerial Photography System! Optimally configured, all the best components to create an awesome aerial platform! Ready to Fly! Pick your packag…
  • Hey great read.
