TAROT ESC do not start the engine
Hi! I´m new in drone hobby and in the last month i bought some parts to mount my own drone. I bought a 6A TAROT ESC (TL300G5) to run a FlyCat motor (3100kv - S1306) with a CC3D FC. After several hours in the internet to understand how to make it work, I finally could flash the last version of a Cleanflight in theCC3D and the last BLHELI firmware in the four ESCs. But until now it is not works properly. The first issue it is because 2 of the 4 motors do not start. It start shaking, but do not rotate. The second issue it is because the other 2 motos (that starts) do not respond correctly, one of then throttle more then the other.
Here the video: https://www.youtube.com/watch?v=HlsW7l7qi_E
Did someone can help?
Thanks a lot!!
Eduardo
    Sounds like loose wiring in those motors. So the timing is not working. Check your joints again.
