Hi, I am testing my APM and for some reason when I switch it into Loiter or RTL it will continuously drift south until it is on the edge of my comfort zone and I take control again (300ft maybe).
The first circle of Loiter and RTL look good but the second is a little south and after 4 or 5 circles it way off and doesn't seem to be heading back. It does seem to be able to "fly" the plane well (PID settings seem right) Stabilize and FBW-A work great. It just seems to have a problem with navigation like the GPS points are moving south or something.
The wind was blowing south about 8 MPH but the plane didn't have any trouble flying up wind when told to manually and was making nice circles when in Loiter or RTL they just didn't keep centered on the right location or even return to the correct center once the got a long way south.
I am flying a basic Bixler with the APM mounted in a Bixler Chassis. I did have a camera on there too for some added weight but Stabilize and FBW-A didn't seem to mind the weight.
I have noticed that when on the ground and hooked up to an XBee (my xbee has very very limited range) that the compass seems to be off. It has the plane pointing in the almost opposite direction. I have checked many times to make sure the APM (new purple v2 board) is pointing in the correct orientation in the plane. Could the Magnets from the chassis be affecting the compass? could an incorrect compass cause loiter to continuously drift south?
THANKS A LOT if you help!
Tags:
Did you calibrate your compass in the Mission Planner?
Permalink Reply by Chad P on April 27, 2012 at 7:52am I did enter/calibrate the "declination" but that is all I remember, would there have been something else? THANKS for the help.
Permalink Reply by Bradley J Carr on April 27, 2012 at 8:05am Is the calibration something that needs to be done? Or can you put in the declination and it be good?
It's best to do the "Live Calibration", too. The MP will instruct you on what to do.
Permalink Reply by Chad P on April 27, 2012 at 9:59am Chris, THANKS A LOT for helping. I don't always get responses from the forums so I really appreciate it when I do.
I entered the Declination but I believe I did it manually. I will try the "Live Calibration".
Could (would you expect) the compass being off to cause the navigation control to send the plane further and further south on each circle? Could that be my navigation issue or do you think they are two separate issues?
Permalink Reply by Chad P on April 28, 2012 at 8:57am So I ran the calibrate procedure a couple of time and got the compass to work better a little but never very reliably. I think the magnets that are attached to the chassis and to the plane are throwing it for a loop. It doesn't surprise me that magnets can effect a magnetometer, but what does surprise me is that other people aren't having this problem with the magnetometer and the Bixler chassis. I do have an extra set on there so there are a total of 6 magnets on the chassis and 6 on the plane which lock together holding the chassis on very very well...but I guess by doing that I lose my compass.
Does the Magnetometer affect navigation in the way I described? What effects will I notice with the compass not working properly?
I think a more likely explanation is that the prevaling wind at that altitude is towards the south and you need to turn up your gains to get more navigation authority. Did you load the Bixler config file? That should be a pretty good start, although it's always a good idea to go through this first-time process to tune the gains for your own aircraft.
You could try flying with the compass disabled. It should still navigate, just not in very straight lines, but it should hit the waypoints reasonably closely.
If the magnets are strong enough the compass will read pretty much the same no matter what the plane's orientation.
Permalink Reply by Chad P on April 28, 2012 at 7:35pm
Permalink Reply by Chad P on April 28, 2012 at 4:22pm
Permalink Reply by Chad P on April 29, 2012 at 1:18pm
Magnets or any large metal mass right by the compass will definitely make it unreliable.
When I move my Quad when its hooked up to my computer, I get a 15 to 20 degree skew when its setting next to the computer. I input the declination from my location using the web site and that works fine, but magnets near the "compass" in flight will absolutely not work and those little canopy magnets they use are extra strong high Gauss rare earth magnets.
I'll bet a lot of people are having this problem and don't even know it.
By the way there is one other possible cause of drift like you mentioned. If you have any trim on the roll or pitch sticks it will continuously displace the GPS point in the direction of the trim.
Because when in any auto GPS mode, the sticks move the GPS point not the plane so any trim acts as an offset which does exactly that.
It is imperative to set up your APM so no transmitter trim is required.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1355 members
203 members
24 members
207 members
58 members
Powered by
