I am studying IMU and planning to test these theoretical equations on PC using software alone.
Does anyone have any idea about dataset or test technique that i could use to verify my equations.
THANKS.
Akshay
Tags: IMU, development
It's not clear exactly what you're looking to test. IMU and equations is kind of broad. :) I personally think a real dataset would be the best (perhaps final) test.
Though working in 2d with a ground vehicle there are some unique issues that aren't really covered and/or which I wanted to investigate myself. I started with a simple simulation of various sensors and then added noise and errors (e.g., simple gyro drift). Later I collected real data from sensors and used that to prototype algorithms and whatnot.
Permalink Reply by Akshay Verma on June 25, 2012 at 9:12am the real data you took from your sensor is what i want! i dont have any hardware with me as of now, so i want hardware data that i could use to test my software routines!
Hope that clears the doubt!!!
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1290 members
51 members
184 members
11 members
182 members
Powered by
