The CLI Log won't log "CURRENT"
Hi all,
I was looking here:
http://code.google.com/p/arducopter/wiki/AC2_datalog
and found I should be able to log the CURRENT if I have a current sensor (which I do), and if it's enabled (which it is).  In config under "Battery Monitor", it says: "4: Volts & Current".  The battery voltage and % remaining seem to be working fine.
Using the CLI in the logs menu, I can enable and disable any parameter such as "MOTORS", "ATTITUDE_MED", etc, but "CURRENT" doesn't seem to be one of them.  I'm using firmware 2.5.5
Can anybody help?
I would REALLY like to be able to log the current, AND also, see it in mission commander.
I need it in the log files for my new APMLogVisualizer software I'm working on:
https://www.youtube.com/watch?v=lAt2dI5Rhzw
Thanks, Dan Gray.
  • HA!
    I just figured out an "undocumented" solution.  I typed "ENABLE ALL" just for fun, and EVERYTHING became enabled.  I then disabled other parameters I didn't need, and everything is fine.
    "Current" is now one of the logging parameters, however, I am not able to disable it by typing "DISABLE CURRENT", it remains enabled.
    But at least I can proceed....
    Dan
