three 3dr radios
Is it possible to have two ground stn radios and one radio in the uav,
I want to have a radio on the ground connected to a laptop running mission planner and the other connected to a tablet running droid planner.
The tablet would be used for monitoring/tracking only and the lap top would be used to update way points etc.
Is such a thing possible if so how,thanks in advance for any help.
  • Hi,
    Yes, this is possible, If you use MPSik - Multipoint SiK, I have demonstrated it on other SiK based modems-
    I will get the latest firmware built for the HM_TRP modules and this should work for you.
    The source for the multipoint firmware is being tidied up and being open sourced shortly.
    Cheers,
    Seppo
