Dear All, Hi, we have an APM 1x board with the 1.02 code and the throttle is not working even if THROTTLE_OUT and THROTTLE_IN are set to one. We have also tried updating to the latest version of the firmware, on the repo but the stabilization doesn't work with that version of the code. in the 1x firmware all the control surfaces including the throttle work and we double-checked the servo connections so it's not a problem with the connections. Also, we tested everything using the CLI and all the tests passed. Would appreciate Help on the matter.
Sriram Rangan
sriram@sriramsr.info
+919880710471
Tags:
The current 2.X code is working fine and many people are flying with it. I would recommend moving to the new code as you will get more help with support.
Start with the simple things... Does the throttle work when in Manual mode? Do the throttle channel values in the radio test make sense?
Permalink Reply by Sriram Rangan on April 28, 2011 at 8:25pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.183 members
1299 members
24 members
48 members
51 members
Powered by
