Hello,
When I configure my RC all 4 channels show the correct measurements when moving to the max positions, but when I move thr throttle it shows on the screen that channel 3 is moving but channel 5 is also moving simultaneously.
So when I go to Flight mode selections and I move the throttle stick the dropdowns go green depending on the throttle sticks position.
Am I doing something wrong or is there somewhere in the software I have to set the channel.
Thank you
Christiaan
Tags:
what firmware? and planner version.
Permalink Reply by Christiaan van Vollenstee on March 2, 2012 at 6:08am Mission Planner 1.1.44 it askes me to update it almost every day. And the firm ware is 2.4.1
can you upload a tlog showing the problem?
Permalink Reply by Christiaan van Vollenstee on March 2, 2012 at 6:13am Where do I get this?
Permalink Reply by Christiaan van Vollenstee on March 2, 2012 at 6:14am Never mind
Permalink Reply by Christiaan van Vollenstee on March 2, 2012 at 6:18am Sorry I found two for yesterday and all I did yesterday was trying to figure this out.
Permalink Reply by Vernon Barry on March 2, 2012 at 6:40am No, No, you guys are chasing the wrong path. His transmitter is obviously set in a helicopter mode which mixes the throttle and collective pitch channel. His receiver is basically sending throttle out on 2 channels. Switch the radio to airplane mode!!! I bet if you look at the transmitter (if it has an LCD), it shows the same thing when viewing the channel outputs (My DX8i did the exact same thing).
If there is no LCD, go back to the manual for the radio. Otherwise, if it's some cheapo fixed heli radio, you may not be able to use it, but thinking since it is mixed, likely it's a switch or a programming function. The quick fix is always airplane mode (no Vtail or other mixing either).
Permalink Reply by Christiaan van Vollenstee on March 2, 2012 at 6:41am Thank you, I will have a look at my transmiiter settings and come back to you.
Permalink Reply by Christiaan van Vollenstee on March 2, 2012 at 6:44am Now that I think of it my LCD is displaying a helicopter logo.
Permalink Reply by Vernon Barry on March 2, 2012 at 6:48am Exactly, an easy fix and hope to see you flying soon.
Permalink Reply by Christiaan van Vollenstee on March 4, 2012 at 11:48pm My reomte has got Helicopter, Glider and Acro what is the best setting?
Acro
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.134 members
24 members
51 members
185 members
1298 members
Powered by
