I have two copters each with it's own transmitter. The problem is they are different types of transmitters. So in order to make it easier to remember the switch assignments on the transmitters, I created a Word file that contains labels.
I thought I would post it here in case it would be of use for someone else. Print it 100% and it will be the right size. Then just cut them out and apply to your transmitter with some clear tape.
Tags:
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
720 members
1355 members
207 members
Powered by
