Whether you are operating a high-performance training drone for pilot skill development, preparing a specialized drone for training scenarios, or managing complex payloads like a delivery drone, unexpected crashes or system anomalies can happen during flight sessions. When things go wrong and you are left wondering about the root cause, having access to reliable flight data is essential.
The EFT Ground Station provides full flight-log download and analysis capabilities designed to help operators pinpoint issues instantly.
http://www.youtube.com/watch?v=b1klGaoeLZo
Flexible Log Retrieval Methods
Depending on your operational setup and storage volume, the ground station supports multiple convenient ways to access and review your flight logs:
SD Card Export: Recommended for large log storage. Simply open the drone's top cover, remove the SD card from the flight-control module, connect it to a computer using a card reader, and navigate to the
EFT/LOGSfolder to save your files locally.Wireless Connection: Link your drone and the EFT Ground Station via radio link, head to the connection menu, and tap the flight-control log download option to read and export data seamlessly.
Wired Connection: Use a standard data cable to connect the ground station directly to the flight-control module for direct wired log management.
In-Depth Analysis and Troubleshooting
Once your logs are downloaded, you can jump straight into the Log Analysis tool within the connection menu. By opening your saved .bin log files, the ground station visualizes comprehensive telemetry data—including attitude, motor PWM values, acceleration, and GPS tracks—allowing technical teams to diagnose faults quickly, verify control performance, and ensure safer subsequent flights.
Have you ever had to troubleshoot a puzzling system anomaly during flight practice? Share your experiences with us!
#EFTDrone #trainingdrone #EFTgroundstation #LogAnalysis #dronecrash #FlightControl #dronelogs #FlightLogs
