I am having a hard time setting up my Xbee's. I follow the manual but only see version 1002 and 1061. The manual says it should be 1161. Which is correct?
Neil
Here is my setup:
Sparkfun xbee pro XBP09-DP modules. One with wire antena and one with 900mhz duck. Both have same identicle setup.
Neil
Use the bottom DOWNLOAD NEW VERSION´s.
When you connect to xbee after atualization the software ask you about atualization then choose yes.
regards and sorry for my poor english,
Thanks for the reply. I have tried to dl new versions many times and it starts to dl and then says server busy try again. If I try again it says no updates found. Is it because I have the sparkfun usb (cable type) with the KB33 regulator?
Neil
I cant find anything on version 1161. Is it a typo in the manual? Should it be 1061?
Neil
Got it working but with version 1061. I cant seam to find any version 1161.
Neil
Neil, could you please explain what steps did you take in order to get it working? I'm asking 'cause I have the same problem that you are facing.
I tried following the manual, but it's unclear about the 1061/1161 issue. So could you please explain all the steps you took, from step 1?
Thanks !
I followed the tutorial exactly except I am using version 1061 instead of 1161.
Neil
