Tuning, Acro, and other autopilots
Working through the (very confusing) process of tuning my quad.  Custom lots of things to make it different from the "stock" frame that a lot use here.  That being said I know that the motors, props and frames will fly well given the right tuning and autopilot platform.
I had 2.5.5 set up on this frame, and it was flying relatively well, with the exception that yaw performance was what I would describe as exceptionally poor.  Bad response time, and the other axis of motion would be affected when yaw was commanded (yaw input caused significant wobbling). Acro was what I would describe as unflyable.  While I was working on the yaw issue, 2.6 became available.
2.6 has brought a whole new series of behaviors and tuning stabilize is far more difficult than it was before. So I'm back retuning, but having issue getting back to where I was.   The other platforms I've used insist on tuning Acro first as a base, then moving up to stabilize.  Why is that not the case here, is the control loop such that it doesn't matter to sabilize?  I can fly an acro quad quite well (as well as a multitude of CP helis),  and I've never had issue tuning them.  Can anyone shed any light on any of this?
Motors are Hacker 20-26M's
150W  1130kV   (I know this is a bit on the high side, and again they have been proven to work well
Props are APC 9x4.7,
APM 2.0
  • At this point, the yaw rate is directly controlled by Yaw_Stab_P parameter.  The higher it is, the faster it will turn.  Unfortunately, this also controls the autopilot control loop, and tuning it up too high can lead to oscillation.
    I plan to seperate these functions out at some point, hopefully soon.
    You can try the simulator. Yaw is pretty low since we use it mainly as a casual flyer and Autopilot. You can increase the Yaw gain to get better performance. Robert has a new Yaw control scheme that is intended to give more performance. It didn't make it into 2.6, but it is being tested now.
    Sim is at www.jasonshort.com
    ArduCopter SIM
