Hi all,
I am a master student currently working for my thesis. I am investigating if its possible to monitor displacements with an uBlox receiver. One of the workflow I want to test is:
- geodetic receiver as base station sends out an RTCM 2.3 stream
- uBlox is my rover (connected to my PC via USB cable)
- internet on my laptop from my smartphone ( WiFi hotspot)
I encounter the following problem:
Step1: Open u-center and connect the uBlox to my PC via USB
Step2: From u-center I go to ''Receiver'' menu then Network connection and then chose TCP option.
At this moment the USB connection is deactivated and I can't get the UBX message from the receiver when I connect to the RTCM stream and pressed the red button for record, everything is freezed, the counting of epochs stays at 0:00:00.
The connection itself works since I see the green icons in the graphic interface.
Another thing tested was to connect to the RTCM stream from RTK lib (input) and then selected as output Serial Port, unfortunately i cant send this to the USB port but only to COM1 (anyway, as far as I know Serial and USB ports are two different things ).
Please check the attached photos.
Can anyone help me ? What should I do in order to get the RTCM corrections? Any help is much appreciated.
Thank you very much for your time.
