Hi guys
Recently I have purchased a UBLOX LEA-6 GPS and plugged to my APM 2.5, but I can not get any signal on my MissionPlanner. I was double checking the connection and noticed the cable which came with GPS has wrong polarity (if I'm not wrong). The GND has red wire instead of black, and 5V port is black. There is a tiny red LED at the back of the board. Is it correct?
Tags:
@Iman,
Try doing a GPS forum search before posting:
http://www.diydrones.com/forum/topics/concern-over-cabling-with-apm...
http://www.diydrones.com/forum/topics/3dr-gps-ublox-lea-6-indicator...
TCIII
Permalink Reply by Iman Sadeghzadeh on December 17, 2012 at 11:13am Thanks Thomas for forum links.
So, according to these discussions, the GPS wiring is ok, but like some other people in these discussions, still my UBLOX doesn't work. Do you have any suggestion?
Regards
Iman
Permalink Reply by Crashpilot1000 on December 17, 2012 at 11:32am Hi!
Did you follow the Wiki - Info: http://code.google.com/p/ardupilot/wiki/ublox ??
So long
Kraut Rob
Permalink Reply by Iman Sadeghzadeh on December 17, 2012 at 11:46am Hi Kraut
Yes, I had a look to wiki, but it talks about reconfiguration issues, which needs the FTDI and GPS adapter cables to connect to the computer. Since they mentioned (in 3D Robotics website) that the GPS module is pre-configured for APM, I didn't order one. Do you think the only way out to this problem is to purchase these cables and do the reconfiguration on the module?
Iman
Permalink Reply by Crashpilot1000 on December 17, 2012 at 11:55am Since i do not own an ublox i can't really comment on that. But having a FTDI Adapter lying around has proved very useful for me in the past with different flightcontrols and mtk gps. I would not want to miss it.....
I don't know if it is the key to your problem but you could wire your gps directly to the pc with it and see it's output with a terminal program (like realterm etc).
So long
Kraut Rob
Permalink Reply by Iman Sadeghzadeh on December 17, 2012 at 8:56pm It's a good suggestion. I think I should order them.
Iman
@Iman,
Chances are that the connector on the LEA-6 is not making good contact with the pads on the printed wiring board. I had an intermittent power problem and had to reflow the connector pins on the printed wiring board which cured the problem.
Just a thought.
TCIII
Permalink Reply by Iman Sadeghzadeh on December 19, 2012 at 9:58am Dear Thomas
Thanks for help. I put 915Mhz radio modem very close to the GPS (shown in the photo), Can that cause the problem?
Iman
Permalink Reply by Bill Bonney on December 23, 2012 at 9:13pm Yes, I would recommend that you don't run those cables over the 915MHz TX. keep the GPS as far away from any transmitter as possible. If you disconnect the radio, you should get a GPS lock if this is the problem.
As for the wrong wiring see this thread http://diydrones.ning.com/forum/topics/3dr-shipped-the-wrong-cable?...
The wires underneath the board where the connector are not aligned with the pads on TOP, confusing to look at, but not incorrect.
If you take a picture of the underneath of the board and post it, we might be able to advise if the connector looks poorly soldered.
Permalink Reply by Bill Bonney on December 23, 2012 at 10:53pm Here's a shot of the underside of my board. The highlighted section show the terminals that TCIII mentions. If they look dull that maybe the problem. To test, and I did this for fun, is to disconnect the GPS board completely front the APM. Then connect 5V between the 5V and GND pads on the topside (I soldered on a couple of wires). I could see the proper power-on red LED and then after a bit the flashing blue LED which means GPS lock.
Permalink Reply by Iman Sadeghzadeh on January 2, 2013 at 11:13pm Hi again
Today I received my FDTI cable as well as my GPS adapter cable. I went through the U-BLOX config link (http://code.google.com/p/ardupilot/wiki/ublox) and completed all steps. So, in the final step (uploading 3DR-Ublox.txt configuration file) I faced this error: "ATTENTION: There were errors/conflicts! Please verify."
As it has been described, the windows should be closed at the end of the process, if everything goes normal. But I got the above-mentioned error. Any idea?
Permalink Reply by Bill Bonney on January 3, 2013 at 11:23pm Do you get the red PWR led on when you power the board, does the blue FIX led flash? or even lock? You picture above just shows that you cannot connect to the GPS as before.
Is there a menu option to read the setting from the ublox? try that. ( I don't have the software or FTDI cable to help)
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
75 members
24 members
184 members
685 members
Powered by
