Ublox M8N altitude error
I am running the M8N with a pixhawk. I was doing some camera calibrations and i notice that the altitude reported by my images was much less than what I was commanding to the vehicle. I verified the discrepancy by taking a pic of a 3x4 wood board and doing the math to figure the height.
Has anyone else experienced this?
  • Much less like how much? cm, meters, km ?
    • at a commanded 200ft the images were saying 135ft.
      • gps altitude is not too accurate but 60 ft difference is quite a lot.
        How accurate is your gps altitude when you are on the ground ?
        Have you tried to read the logs and check the difference between baro and gps ?
        • gps alt is right on what google earth says the elevation is.
          baro alt is reading in agl
          GPS seems accurate at the ground
          • Francisco, what is the gps vs baro alt (difference) ?
            • 350ft which is msl elevation of the launch area
