Hi everyone,
I'm having some problems updating the GPS Firmware (my Lon
values are completely out of range, Lat is O.K.). Now I don't own an
FTDI cable, so i'm stuck with the pass-through method using the script
in the APM manual (attached).
Which baudrates should I set in the script, and what baud rate should the flash tool be communicating with?
I Tried 38400 for the APM (IMU?) and 9600 or 115200 for the GPS. Set the flash tool at 38400.
Result: [Flash Download],Fail!!(Download) DL_HANDLE error code,[Finish]
----------------------<SERIAL CODE FROM MANUAL>--------------------------------
void setup()
Serial.begin(38400); // FTDI; this is the speed at which the IMU board is communicating with your PC
Serial1.begin(9600); // GPS; 9600 is the usual default for NMEA GPS modules
delay(10000);
void loop()
if (Serial.available())
Serial1.write(Serial.read());
if (Serial1.available())
Serial.write(Serial1.read());
----------------------</SERIAL CODE FROM MANUAL>--------------------------------
PS: Running the APM Beta code - gps test mode. Here I noticed the values of Lon being out of range. Should be showing 9.xxxxx instead I see around 60.xxx
Tags: APM, FTDI, GPS, Media, Serial, Tek, Update
▶ Reply to This
